ITC normalization?
- Kevin
17 Mar 2021 08:03 #9379
by Kevin
ITC normalization? was created by Kevin
I am looking to model the impact of ITC normalization required for utility ownership (spreading the ITC over the life of the project) compared to PPAs from third-parties (applying 5-year MACRS). What financial models and settings will most directly mimic a rate-base return for utilities?
Kevin
Kevin
17 Mar 2021 17:01 - 17 Mar 2021 17:01 #9380
Replied by Paul Gilman on topic ITC normalization?
Hi Kevin,
I was not aware of this tax normalization issue for for-profit utilities, but found these helpful articles to learn about it:
I am a little confused by your question about "rate-based return" because I'm not sure how that term relates to "ITC normalization."
- www.utilitydive.com/news/itc-tax-normalization-limits-solar-growth-and-favors-fossil-fuels/577920/
- www.communityenergyinc.com/solaritcpaper
Last edit: 17 Mar 2021 17:01 by Paul Gilman.
- Kevin
17 Mar 2021 17:14 #9382
by Kevin
Replied by Kevin on topic ITC normalization?
Paul,
Thanks for the reply. IOUs are required to spread the ITC over the life of the project, so a 30-year asset would get 1/30 of the ITC benefit each year. Maybe setting a custom depreciation schedule at 3.33% per year and ticking the ITC check marks might accomplish this?
The rate-based return comment was not directly related to the ITC normalization. I was referring to cost of service regulation where the utility gets straight-line depreciation of the asset and earns a regulated rate of return on the net asset value plus recovery of expenses and taxes Essentially, I am trying to compare the revenue requirement of a utility-owned, rate-based project to a PPA from an IPP for the same size project with the same capital costs. I am not sure which model best duplicates the utility ownership structure.
Kevin
Kevin
18 Mar 2021 13:23 #9383
Hi Kevin,
SAM's PPA models are designed for IPP projects, so they do not have these features that would apply to an IOU owner.
For the normalized ITC: I think you could model this by setting the ITC on the Incentives page to zero and reducing the Federal Tax Rate by the normalized ITC amount. For example, given a federal income tax rate of 30%, 26% ITC, and 30-year analysis period, you would use Federal Tax Rate = 0.30 - 0. 26 * 0.0333 = 0.291, or 29.1%.
The "ITC Qualification" check boxes on the Depreciation input page determine whether the portion of the capital cost associated with a given depreciation class qualifies for the ITC. But, for this normalized ITC, we are setting the ITC to zero, so the check boxes should have no effect on the results.
- Weimin Dang
06 Apr 2023 22:40 #12038
by Weimin Dang
Replied by Weimin Dang on topic ITC normalization?
Hi Kevin, if you would like to discuss ITC normalization modeling, I would be happy to do that. - Weimin
