HCPV's module parameters
  • sultan
14 Feb 2021 00:51 #9287 by sultan
HCPV's module parameters was created by sultan
I need to use specific HCPV panels.
I couldn't found the parameters that SAM require for HCPV on an external module  Data sheet  ,
does SAM use specific HCPV module, if yes where can i found it? if no how can i insert the parameters of the external panel?
www.bsqsolar.com/wp-content/uploads/datasheet/Datasheet-BSQ-D280%20HCPV%20Module-v2.4-3T.pdf
18 Feb 2021 18:13 #9306 by Paul Gilman
Replied by Paul Gilman on topic HCPV's module parameters
Hi Sultan,
You can use the equation from SAM's Help system in the definition of  "Overall module area" to calculate the cell area from the module area and concentration ratio provided on the datasheet.
For the loss parameters, you can just use SAM's default values.
The datasheet says it is an "abridged data sheet." You might see if you can get the full version of the datasheet from the manufacturer.
