Dear Vijay,
As a workaround until the January update, you can use Subarray 2 to import the Suneye shading data. On the PV Subarrays page, enable Subarray 2, and set the number of strings allocated to subarray 2 equal to the total number of strings in the array. That will cause the number of strings allocated to Subarray 1 to be zero. Click Edit Shading for Subarray 2, and import your Suneye shading data. (This models your system as a single array, but uses the Subarray 2 inputs to describe it instead of the Subarray 1 inputs. The issue with shading data only applies to Subarray 1)
