Difference between Generic CSP Model and Parabolic Trough (empirical)
- Daniel Liu
03 Jan 2021 14:25 #9146
by Daniel Liu
Difference between Generic CSP Model and Parabolic Trough (empirical) was created by Daniel Liu
Hello, Paul!
I'm currently trying to model a CSP solar system capable of powering a multi-solar flash desalination unit. However, I'm unsure whether to use the generic CSP model or the empirical parabolic trough model. What's the difference between the two?
05 Jan 2021 09:24 #9148
Replied by Paul Gilman on topic Difference between Generic CSP Model and Parabolic Trough (empirical)
Hi Daniel,
From SAM's Help system, the physical trough model is described as:
The physical trough model calculates the electricity delivered to the grid by a parabolic trough solar field that delivers thermal energy to a power block for electricity generation, with an optional thermal energy storage system. The physical trough model characterizes many of the system components from first principles of heat transfer and thermodynamics, rather than from empirical measurements as in the empirical trough system model. While the physical trough model is more flexible than the empirical trough model, it adds more uncertainty to performance predictions than the empirical model.
And the empirical trough model:
The empirical trough model models the same type of parabolic trough system as the physical trough model, but uses a set of curve-fit equations derived from regression analysis of data measured from the SEGS projects in the southwestern United States, so you are limited to modeling systems composed of components for which there is measured data. The model is based on Excelergy, originally developed for internal use at at the National Renewable Energy Laboratory.
In general the physical trough model is the best choice. The empirical trough model is based on older designs, but is suitable when you need faster simulations.
For a thermal application like a desalination plant, you may want to consider using the Parabolic Trough - Heat model, which is similar to the physical trough model, but without the power cycle.
- Daniel Liu
11 Jan 2021 13:39 #9173
by Daniel Liu
Replied by Daniel Liu on topic Difference between Generic CSP Model and Parabolic Trough (empirical)
Hello Paul,
Is there a similar model to the physical trough -heat model that also outputs economic values such as Net Present Value or capital cost? I'm looking for a solar thermal system that doesn't have a power cycle (leaves thermal energy produced as is) while simultaneously being able to model the economic values related to the solar component.
11 Jan 2021 13:48 #9175
Hi Daniel,
The IPH Trough model uses a simple fixed charge rate (FCR) method for calculating the "levelized cost of heat". There is not a cash flow model available for the industrial process heat models in SAM.
