Negative annual energy
- Francesca
12 Nov 2020 08:06 #8993
by Francesca
Negative annual energy was created by Francesca
I designed a molten salt power tower model, where use the 'optimize heliostat layout', then try to simulate the amount the energy that is produced from the design per year. But I just got a negative value like -3377281KWh. Could you explain that is there any reason that would cause a negative number ?
Francesca
Francesca
13 Nov 2020 16:29 #9001
Replied by Paul Gilman on topic Negative annual energy
Hi Francesca,
Can you attach a copy of the .sam file that generates those negative results?
- Francesca
15 Nov 2020 06:29 #9004
by Francesca
Replied by Francesca on topic Negative annual energy
Here is the file. I'm using SAM 2015.1.30. Please help me have a look at this model. Thank you.
Francesca
Francesca
16 Nov 2020 10:08 #9007
Hi Francesca,
The Power Cycle input parameters "Estimated Gross to Net Conversion Factor" and "Rated Cycle Conversion Efficiency" are both set to 1. Changing those to a more realistic 0.9 and 0.4, respectively, results in positive annual energy.
