Running inverter at reduced capacity
- Solpwr
11 Nov 2020 14:30 #8991
by Solpwr
Running inverter at reduced capacity was created by Solpwr
When we are using central inverters (example 3.5MVA quantity of 2) however we are only trying to limit the project site to 6MVA. Is there a way to specify it in the system design stage to dictate that the inverters are not going to be used at full capacity.
13 Nov 2020 16:33 #9002
Replied by Paul Gilman on topic Running inverter at reduced capacity
You could use the grid interconnection limit on the Grid Limits page to limit the AC output of the system.
You could also use the inputs on the Losses page to reduce the output of the array (DC) or inverter (AC).
