2018.11.11 version VS 2020.2.29 version
- Mehdi5977
27 Jul 2020 18:38 #8488
by Mehdi5977
2018.11.11 version VS 2020.2.29 version was created by Mehdi5977
I compared the default molten salt tower cases using the 2020 and 2018.11.11 versions. I used des_moines as the location.
The output is different, 2018 version gave the value that was around 5% higher. I wanted to investigate further, so I started with comparing the incident thermal power on the field, that was slightly different too. In fact, for some DNI values mainly at the end of day version 2018 had thermal power while 2020 version didn't. The optical efficiency was also higher for 2018 version, and therefore all other parameters are higher after the solar field.
Is this something you are aware of and part of the modifications you made to the 2018.11.11 version?
Many thanks
Many thanks
29 Jul 2020 09:28 #8494
Replied by Paul Gilman on topic 2018.11.11 version VS 2020.2.29 version
Hi Mehdi,
You can use the release notes to see what changes we made to the models between versions: nrel.github.io/SAM/doc/releasenotes.html .
I am not aware of any changes to the Molten Salt Power Tower model that would explain a 5% difference in total annual output for the default system. The default system design is optimized for Daggett, California, so the difference could be caused by changing the weather file to Des Moines, Iowa.
- Mehdi5977
30 Jul 2020 22:39 #8509
by Mehdi5977
Replied by Mehdi5977 on topic 2018.11.11 version VS 2020.2.29 version
I ran the default cases using Daggett data, the difference is lower, around 2%, but still exists. When I checked different parameters such as optical efficiency, input to the power block, and power block efficiency there are small differences. I checked the release note and couldn't find any item that can cause this.
Many thanks,
Mehdi
Many thanks,
Mehdi
04 Aug 2020 10:23 #8520
Hi Mehdi,
The CSP team has identified the cause of this difference as a new cooling model implemented for the Rankine cycle in SAM 2020.2.29. Please see the revised release notes for a description:
nrel.github.io/SAM/doc/releasenotes.html#2020-2-29-mspt
Thank you for bringing this to our attention.
