Solar PV Capacity Factor
  • Hamilton Steimer
20 Jul 2020 15:44 #8453 by Hamilton Steimer
Solar PV Capacity Factor was created by Hamilton Steimer
How would one increase the capacity factor for a solar PV plant? Currently, mine is at 17.5% which is fairly low (should be around 23%). Is it based on weather data or system design or financial factors? Thank you very much for any help you can provide!
Best,
Hamilton
20 Jul 2020 17:43 #8454 by Paul Gilman
Replied by Paul Gilman on topic Solar PV Capacity Factor
Hi Hamilton,
The capacity factor is a measure of the system's performance, so financial assumptions do not affect its value.
Some examples of things that might cause the capacity factor to be low for a photovoltaic system are: the array is oriented away from the sun, or modules are spaced too closely together, or the inverter is too small for the array.
