The field pumping power is the energy required to operate HTF circulation pumps in the solar field. SAM uses a detailed model based on the physical properties of the field to calculate this parasitic loss. For a description of how SAM calculates the value, see Section 2.5 of the physical trough reference manual.
The power cycle/TES pumping power is the pumping power required by both the power cycle and TES. For your system with no TES, the value represents the energy required by fluid pumps in the power cycle. SAM calculates the pumping requirements of the field, TES, and power cycle separately because the power cycle model does not have sufficient detail to calculate the losses based on physical properties. See Section 5.2.2 in the physical trough reference manual for a detailed explanation.
You can download the physical trough reference manual from the
Performance Models page
