Eurotrough 150
  • Wilvard
13 Apr 2020 20:39 #8115 by Wilvard
Eurotrough 150 was created by Wilvard
How to determine the heat loss in absorber tubes of eurotrough 150 by using manual calculations?
See picture below for the specifications of ET 150
14 Apr 2020 16:32 #8118 by Paul Gilman
Replied by Paul Gilman on topic Eurotrough 150
Hi Wilvard,
SAM's Physical Trough model has parameters for the EuroTrough ET150 collector in the collector library: To use it, select the trough in the Collector Library list and then click Apply Values from Library to use the parameters for each collector type included in your design.
The heat loss parameters are on the Receivers page, and the heat loss at design calculations are shown in the Help topic for that page.
