DEBUGING
  • Manuel Acosta
27 Mar 2020 07:32 #8074 by Manuel Acosta
DEBUGING was created by Manuel Acosta
When I run the analysis for solar PV and want to check the cash flow, the screen is stuck. I need to re-run the system for de-freeze the cash flow screen. Also, the Battery top down buttoms have some troubles because are not accesible easily.
27 Mar 2020 14:32 #8079 by Paul Gilman
Replied by Paul Gilman on topic DEBUGING
Dear Manuel,
Thank you for the feedback. Could you tell me what version of SAM (2020.2.29, 2018.11.11, etc.) you are using, and on what operating system (Windows, Mac, Linux)? Could you attach a copy of your .sam file so I can try to replicate this behavior?
For the Battery Storage page, sometimes the vertical scroll bar does not appear when you need it to see the entire page. When that happens, try minimizing and then maximizing the SAM window, and the scroll bar should appear.
