Warning in CSP Empirical trough model
  • Alvaro Albertini
05 Mar 2020 07:36 #8022 by Alvaro Albertini
Warning in CSP Empirical trough model was created by Alvaro Albertini
Hello all,
It is great to have the possibility to communicate with all of you through this Forum.
I am curious about a warning I receive in some of my CSP Empirical Trough simulations. I am aware these are not errors and the outputs are still calculated, but I would like to know what they mean and how to decode the logs.
One example of the warning follows:
time 2538000.00 { Test Trough 2 }:
Warning - Empirical trough (805) model exceeded interal iteration limit
I realize the warnings are related to the weather input I provide. However, the weather check macro always gives positive results to the all weather files I try.I understand maybe the simulations constraints for the convergence are too strict in this case. Is there a way to relax them? Also, is there a way to decode the time Information and find in which step is my Simulation not converging? Do you have any ideia why could be the reason of this?
Any comments and help from all of you will be much appreciated!
Attached is the weather file and the csp Project I used for this Simulation.
I wish you all a very nice day!
Alvaro
13 Mar 2020 10:12 #8036 by Paul Gilman
Replied by Paul Gilman on topic Warning in CSP Empirical trough model
Dear Alvaro,
SAM's performance models use iterative methods to solve for values in internal calculations. The error message you saw says that one of these methods failed to converge on a solution within the number of iterations allowed by the person who wrote the algorithm. Unfortunately, it does not say what value it was attempting to calculate, but the model did assign a value so it could complete the simulation. The value may be a temperature or power value at some node of the system for a single time step so using a default value would not have a significant effect on the model output. In general, if there are only a few of these messages out of the 8,760 time steps in an hourly simulation, you can ignore them. If there are error messages for a large number of time steps, it may indicate that there is a problem with one or more inputs that need to be fixed.
