Rates for demand charges in the Dominican Rrepublic
  • Carlos Liquet
02 Mar 2020 18:58 - 13 Mar 2020 10:19 #8019 by Carlos Liquet
In my country for residential and commercial building for peak demand up to 10 kW the demand charge is $0; however for peak demand beyond 10 kW the charge ($/kW) is calculated based on the average of the two months with the highest peak, then all sub-sequence months throughout  that year will be charged with this fixed value. See file attached for illustration. Question, How may I setup this method in "Rates for demand charges" section?
Best Regards,
Carlos
Last edit: 13 Mar 2020 10:19 by Paul Gilman.
13 Mar 2020 10:29 #8038 by Paul Gilman
Replied by Paul Gilman on topic Rates for demand charges in the Dominican Rrepublic
Dear Carlos,
I think you could approximate this structure for demand charges as follows:
1. Run a simulation with no demand charges to identify the two months with the highest peak and calculate the average $/kW rate.
2. Enable demand charges, and set the tiered demand charge rate using the average value you calculated for $/kW.
3. Run a simulation with demand charge to calculate the electricity bill savings.
  • Carlos Liquet
13 Mar 2020 13:12 #8040 by Carlos Liquet
Replied by Carlos Liquet on topic Rates for demand charges in the Dominican Rrepublic
Thanks Paul for your help on this!
Carlos
