Issue with battery charging in peak-shaving mode
- Nelson Koch
14 Feb 2020 02:04 #7979
by Nelson Koch
Issue with battery charging in peak-shaving mode was created by Nelson Koch
I was running some simple simulation :
As you can see in the plot below, the battery correctly shaves the grid power and discharges to 12%. After the even, the battery is recharged (red square) back to 100%. Although the battery power seems correct, the grid power stays null during the whole phase. It is the same for the "Bill load".
It seems then that the battery is charged from nowhere and this energy is not accounted in the energy bill. Could you confirm that?
You will find attached the .sam file of the project.
Best,
Nelson
- Generic/Residential model
- With SAM 2020.1.17
- Battery in peak-shaving mode (allowed to charge from the grid)
- No local electricity production (power plant losses at 100%)
Best,
Nelson
24 Feb 2020 16:08 #8000
Replied by Paul Gilman on topic Issue with battery charging in peak-shaving mode
Hi Nelson,
Sorry for the delay -- we are investigating this issue.
- Nelson Koch
04 Mar 2020 03:30 #8021
by Nelson Koch
Replied by Nelson Koch on topic Issue with battery charging in peak-shaving mode
I just downloaded and tested the latest version of SAM (2020.2.29) and it seems that this problem has been solved. Could you confirm that?
Nelson
Nelson
