15-minute Weather File
- Ángel Menor
25 Sep 2019 10:03 - 25 Sep 2019 11:43 #7676
by Ángel Menor
15-minute Weather File was created by Ángel Menor
Hello.
I am facing a problem working with SAM CSP Trough scenario.
When using 1 hour weather files (8760 data lines) SAM runs well and produces a nice output
Anyhow, if I expand the input to 15-minute weather files (35,040 data lines) SAM only takes into account the first 8760 lines (as in the image below).
Is it possible to feed SAM with a 15-minute input (not using solar resource interpolating macro)?
Last edit: 25 Sep 2019 11:43 by Paul Gilman.
25 Sep 2019 11:42 #7677
Replied by Paul Gilman on topic 15-minute Weather File
Hi Angel,
Please see this post about subhourly simulations in SAM's CSP models:
sam.nrel.gov/forum/forum-general/2013-sub-hourly-simulation-for-linear-fresnel.html#6267
Your image did not upload correctly, so I removed it. It may work better to attach images instead of pasting them into the message.
- Ángel Menor
26 Sep 2019 01:23 #7681
by Ángel Menor
Replied by Ángel Menor on topic 15-minute Weather File
I am actually trying to work with an Empirical model, so that is the reason it is not working.
Thank you very much for your promt reply, Paul. Regards.
