Central tower receiver analysis without financial information
- ryank23
01 Oct 2012 09:24 #917
by ryank23
Central tower receiver analysis without financial information was created by ryank23
The GUI for SAM is much better than DELSOL3, especially when entering the heliostat field positions. Is there a way to operate SAM for a central tower without the financial analysis?
I need to check a system being designed by a research firm to see if their values are correct, specifically the heat flux on a cavity receiver. The design of the tower is likely to change since it is part of research, but the heliostat field will remain constant. Because of that, I would like to run simulations with different receivers.
Essentially, if I could, I would use SAM for the heat flux analysis of the heliostat field on the receiver tower without having to input money concerns. Is this possible, or should I go to DELSOL3?
02 Oct 2012 13:03 #918
Replied by Paul Gilman on topic Central tower receiver analysis without financial information
You can specify your own heliostat field layout on the Solar Field page, and then run SAM to generate a flux map. SAM uses DELSOL to calculate the flux map, so that should accomplish what you want.
There is a discussion of how to find the flux map files here:
PTGen/DELSOL3 intermediate results for CSP Power Tower model
