CSP PTC plant efficiency
- Lukas Richter
30 May 2019 05:08 #7332
by Lukas Richter
CSP PTC plant efficiency was created by Lukas Richter
I am just getting started with SAM, so my question may be a bit stupid, for which I am apologizing. Nevertheless I would like to ask you how to get the overall efficiency of a CSP parabolic trough power plant. I would expect values somewhere between 20-30% and I cannot find this within the evaluation of simulation results. The capacity factor is not efficiency, is it? Thank you for your advice.
Lukas
Lukas
30 May 2019 10:40 #7341
Replied by Paul Gilman on topic CSP PTC plant efficiency
Hi Lukas,
SAM does not report an overall system efficiency. The capacity factor is one measure of the system's efficiency, which SAM calculates as
You could use the data on the Statistics tab of the Results page to calculate the efficiency of different parts of the plant. For example, to calculate the overall incident irradiance to net electrical output, you could divide the sum of "System power generated" by "Field thermal power incident after cosine".
Capacity Factor = Net Annual Energy (kWhac/yr) / System Capacity (kWdc or kWac) / 8760 (h/yr)
