Loop Thermal Energy Output (MWht)
  • sidom
12 Sep 2012 08:36 #839 by sidom
Loop Thermal Energy Output (MWht) was created by sidom
I am modeling a CSP plant and I want to obtain the Loop Thermal Energy in Kwatts. From the Hourly Data I can take some information like:
Solar Field Thermal Output (MWh), Thermal Energy Absorber(MWh) or Thermal Energy to P.B. (MWh).
¿Which is the most accurate parameter to obtain the loop thermal Energy (dividing this parameter between the number of loops)?
¿Which losses are taken into consideration in between each parameter?
Thanks in advance
13 Sep 2012 11:30 #840 by Paul Gilman
Replied by Paul Gilman on topic Loop Thermal Energy Output (MWht)
I recommend reading the first few sections of Chapter 2 "Solar Field" of the physical trough reference manual (see the link on the Performance Models page) to understand how SAM calculates the solar field energy balance.
What do you mean by "loop thermal energy?" Do you mean the solar energy absorbed by a single loop?
  • sidom
14 Sep 2012 03:44 #841 by sidom
Replied by sidom on topic Loop Thermal Energy Output (MWht)
Yes, that's what I am trying to obtain, Thermal Energy absorbed by each loop.
Thanks and regards
14 Sep 2012 09:29 #842 by Paul Gilman
I think it would be reasonable to approximate the thermal energy absorbed by each loop by dividing the hourly result variable "Thermal energy absorbed (MWh), hourly" by the number of loops in the field.
