Solar Tower molten salt
08 Oct 2024 11:28 #13508 by Paul Gilman
Replied by Paul Gilman on topic Solar Tower molten salt
Hi Alsadi,
SAM does not explicitly model turbine outlet conditions. Instead, it uses a normalized cycle performance map that relates HTF temperature, HTF mass flow rate, and condenser pressure. SAM converges condenser pressure based on ambient conditions and off design performance of the cycle cooling technology (i.e., evaporative cooling, air-cooled condenser, hybrid cooling, or surface condenser).
Steam cycles typically operate at saturated vapor conditions (or slightly condensed) at the low-pressure turbine outlet. The condenser outlet condition is assumed to be saturated liquid. Therefore, the condenser inlet temperature and pressure are equal to the outlet conditions.
