Hourly control- Fossil backup
- kika
27 Aug 2012 06:11 #804
by kika
Hourly control- Fossil backup was created by kika
I am simulating the CSP plant performance using the empirical model of SAM ( latest version). I would like to modelize the plant using fossil backup with defined power in each hour (8760 input data ) . is that possible?
Also, I would like to know how can I define the thermal storage control to prioritize the fossil backup , with and without sun, and with and without TES?
Thanks in advance.
Thanks in advance.
27 Aug 2012 11:58 #805
Replied by Paul Gilman on topic Hourly control- Fossil backup
It is not possible to simulate a parabolic trough system using fossil backup power as an input. SAM uses the inputs you provide under Thermal Storage Dispatch Control on the Thermal Storage page to determine when the system requires energy from fossil backup to supply supplementary heat to the field HTF.
SAM uses energy from the fossil backup system when there is insufficient energy from the solar field or TES to maintain the field design temperature. I don't think there is a way to trick the model into prioritizing fossil backup.
What application are you trying to model using this approach?
- kika
30 Aug 2012 05:37 #806
by kika
Replied by kika on topic Hourly control- Fossil backup
Thanks Paul for your quick response.
I would like to model a hybrid plant. A biomass plant that generates as a given profile (8760 data). CSP should complement to the maximum load. If the biomass plant produces the maximum CSP should store energy in TES.
04 Sep 2012 11:04 #807
SAM does not model hybrid power systems. You can model a biomass power plant or a CSP power plant, but not a combination of the two.
