Solar Edge Inverters
- John Jevahirian
15 May 2019 19:48 #6800
by John Jevahirian
Solar Edge Inverters was created by John Jevahirian
Can you please take a look at the Solar Edge 480v Inverters in SAM's database? It appears that the data sheet parameters are not accurate to the inverters spec sheet. Looking at the 33.3K-US specifically, but have had problems with the whole line of 480v inverters.
Also, I had placed a discussion topic on this forum about a week ago (from the looks of it, prior to the new web interface NREL rolled out) and now I cannot find my discussion topic on Rate Schedule modeling for new rate structure in Michigan. I also had to make a new account for what it is worth...
J
J
15 May 2019 19:48 #6801
Replied by Paul Gilman on topic Solar Edge Inverters
Sorry about the bumps in the road as we transition to the new website. We're still moving posts from the last several months over to the new forum, so that thread should appear in this forum in the next day or so.
As for the inverter data, we get the data from the California Energy Commission. You can see the data in the workbooks posted on the GoSolar California website: www.gosolarcalifornia.ca.gov/equipment/inverters.php .
Would you mind checking to see if the data for the inverters you are working with is correct in the "full data" workbook? That data should be consistent with the data in SAM.
