PySSC : no attribute 'pdll'
- KillianPremel
23 Apr 2019 08:40 #6755
by KillianPremel
PySSC : no attribute 'pdll' was created by KillianPremel
I am on Linux and I try to use SDK with Python, to create automatically the results of a study ( I downloaded SAM and SDK).
I just begin with SAM and SDK, so I wanted to follow the tutorial on nsrdb.nrel.gov/api-instructions , but it doesn't work when I try to run this line : ssc = sscapi.PySSC().
The error is that 'PySSC' object has no attribute 'pdll', when I looked in the file there is an attribute pdll, but only for Linux2
I found that the platform is not supported with Linux.
Is there a way of doing it with Linux ?
Killian Premel
Killian Premel
23 Apr 2019 17:23 #6756
Replied by Paul Gilman on topic PySSC : no attribute 'pdll'
Dear Killian,
The example on the NSRDB website is for an older version of SAM (SAM 2015.6.30). I would recommend starting by generating Python code from the current version of SAM as described on the SAM SDK page: sam.nrel.gov/sdk -- generate the code from a PVWatts/No Financial Model case -- and then once you get that running, modifying it to use the
object as described in the NSRDB API example.
wfd
