Biomass capacity
- Alice
28 Mar 2019 07:44 #6725
by Alice
Biomass capacity was created by Alice
I try to do my biomass model in SAM ,however, the capacity is automatically calculated by SAM.
Is there any possible ways to specified Biomass capacity?
and I found the webinars for Biomass but it was in 2012.
is there any of the latest example for biomass?
or could you provide some example or studies for Biomass with SAM?
Best Regards,
Thanun
Best Regards,
Thanun
29 Mar 2019 12:51 #6726
Replied by Paul Gilman on topic Biomass capacity
SAM's Biomass Combustion model calculates the power plant capacity based on the parameters on the Feedstock input page, so you should adjust those parameters to achieve a particular plant capacity.
The model has not changed since it was first developed in 2012, so the information in the webinar is still valid for the latest versions of SAM.
When you create a Biomass Combustion case in SAM, you can use the default system as an example to get started with the model.
