Rated Cycle Convertion Efficiency Vs Turbine Efficiency
  • sidom
18 Jul 2012 03:58 #717 by sidom
SAM input data request Rated Cycle Convertion Efficiency. Turbine Manufacturers provide in their Heat Balance values for Turbine Efficiency (or Heat Rate). How can we relate one value into the other? What losses/parameter relate one to another?
How does SAM (Physical Model) consider conversion efficiencies at partial loads?
Thanks a lot.
19 Jul 2012 14:07 #718 by Paul Gilman
Please see Chapter 3 The Power Cycle of the physical trough reference manual for a description of how the physical trough model represents the power cycle.
  • sidom
23 Jul 2012 11:01 #719 by sidom
Does SAM take into consideration efficiency losses in heat exchangers in "Rated cycle conversion efficiency" parameter? Is this parameter the efficiency of the whole power block?
Thanks and regards
