CSP Physical Trough Total loop conversion efficiency
- rnalvar
24 Mar 2019 19:59 #6719
by rnalvar
CSP Physical Trough Total loop conversion efficiency was created by rnalvar
Can I ask for the equation used in calculating the Receiver Heat Loss Efficiency which is used for the Total loop conversion efficiency calculations? Thank you very much
29 Mar 2019 12:54 #6720
Replied by Paul Gilman on topic CSP Physical Trough Total loop conversion efficiency
The equations for the calculated design point parameters are in SAM's Help system under CSP Parabolic Trough, Physical Trough Model, Solar Field (or press the F1 key from the Solar Field input page), then scroll down to the "Equations for Calculated Values" section of the Help topic.
