Unable to download wind data using the "Download a wind resource file from the online NREL WIND Toolkit" option
- smadala
05 Mar 2019 20:10 #6670
by smadala
Unable to download wind data using the "Download a wind resource file from the online NREL WIND Toolkit" option was created by smadala
I am encountering the following error:
"Retrieving data at lattitude = 39.74 and longitude = -104.99
Downloading data for 60m hub height.
Failed to read downloaded weather file C:\Users\smadala/SAM Downloaded Weather Files/lat39.74_lon-104.99__2013."
Any guidance on how to proceed is much appreciated. Thank you!
06 Mar 2019 11:02 #6671
Replied by Paul Gilman on topic Unable to download wind data using the "Download a wind resource file from the online NREL WIND Toolkit" option
The NREL WIND Toolkit web service has been down, but it should be working now. Please try again and let us know if you continue to have trouble.
- Guilherme Larangeira
23 Aug 2019 13:05 #7621
by Guilherme Larangeira
Replied by Guilherme Larangeira on topic Unable to download wind data using the "Download a wind resource file from the online NREL WIND Toolkit" option
I'm getting same thing now.
"Retrieving data at lattitude = 40.00 and longitude = -73.00
Downloading data for 100 hub height.
Failed to read downloaded weather file C:\Users\Glarange/SAM Downloaded Weather Files/lat40.00_lon-73.00__2013. Try the download again in case there was a problem connecting to the database."
General question: Is the Python API more robust? I could try using that. Whatever works best, please LMK.
Gui
Gui
26 Aug 2019 16:38 #7626
Hi all,
The best we can suggest for now is to keep trying the download until it works. The problem is with the WIND Toolkit API, so working through a different path will not fix it.
28 Apr 2023 09:45 - 02 May 2023 10:30 #12089
Wind resource data downloads are not working in SAM 2022.11.21 r1. We will fix that for the next update.In the meantime, use the attached LK script as a workaround:
- Download the attached wtk-download.lk script.
- Start SAM and create or open a wind case.
- On the File menu, click Open script and open the wtk-download.lk script.
- In the script, replace the values in Lines 19-22 for the year, timestep, longitude, and latitude variables with values for the file you want to download.
- Click Run at the top of the script editor.
Last edit: 02 May 2023 10:30 by Paul Gilman.
