SAM Incidence Angle Calculations
- Photomofo
26 Feb 2019 16:32 #6662
by Photomofo
SAM Incidence Angle Calculations was created by Photomofo
Good Afternoon,
I'm having trouble deciphering the single axis tracking code in SAM. Specifically what I'm trying to do is model the Utility PV plants in the Solar Integration Dataset. Here's the basic equation I'm using:
ARG = sin(zen) * cos(azm - sazm) * sin(tilt) + cos(zen) * cos(tilt)
if ARG = XYZ then
blah blah
end if
inc = acos(ARG)
This is a horizontal mount system with a north to south orientation. My assumption are:
sazm = azm
tilt = 0
I've tried moving these assumptions this way and that but nothing is coming out correctly. I've read the Technical Reference documents and I've experimented with alternate INC calculations. I've double checked by zen and azm calcs and they come out fine.
Note also that my calculations for Fixed systems are coming out fine as well.
Can someone point me in the right direction? Is there a forum related to the Open Source release of SAM on GitHub?
if ARG = XYZ then
blah blah
end if
inc = acos(ARG)
sazm = azm
tilt = 0
27 Feb 2019 14:29 #6663
Replied by Paul Gilman on topic SAM Incidence Angle Calculations
I am not familiar with the data in the Solar Integration Data Sets. You may want to try emailing the contact person on the program's website:
www.nrel.gov/grid/solar-power-data.html
