Load Profile in SAM
  • Pia Rodriguez
28 Jan 2019 12:49 #6620 by Pia Rodriguez
Load Profile in SAM was created by Pia Rodriguez
Can SAM work with a hourly utility load profile and see how is it affected by PV generation and Storage?
29 Jan 2019 14:27 #6621 by Paul Gilman
Replied by Paul Gilman on topic Load Profile in SAM
Dear Pia,
When you model a PV-battery system with either the Residential or Commercial financial model, you can model a building electric load. SAM assumes that the grid is available to either absorb excess power from the system or deliver power as needed to meet the building load or charge the battery, depeding on the dispatch options you specify.
For the PPA financial models, SAM assumes that the grid is available to absorb power from the system, and to deliver power as needed to charge the battery, depending on the dispatch options you specify. You can use the "Input Battery Dispatch" option to manually specify when the battery charges and discharges, but it is not possible to define a load profile for the grid.
