3D shading calculator
- bpm77
09 Jan 2019 12:39 #6589
by bpm77
3D shading calculator was created by bpm77
Hello Paul,
I'm trying to use the 3D shading calculator for the file attached. However, once I click to save the model the warning in the box appears (for all subarrays).
I do understand that, for example, my first active surface is subarray 1 - string 1 and I have in total 123 strings for this subarray. My question is: how do I include all my strings? It seems that each subarray only supports 8 strings, therefore it looks to me that I cannot do it. Am I missing something? Is there a way around this?
Thanks for the support,
Bruno
Bruno
23 Jan 2019 11:25 #6590
Replied by Paul Gilman on topic 3D shading calculator
Dear Bruno,
Thank you for the message.
The 3D shading tool is designed to calculate shade losses for a residential rooftop system, where trees, neighboring buildings or other nearby objects shade the array. These systems typically have just a few strings, so the limit of 8 works for those.
If you using the 3D shade calculator to model self shading caused by neighboring rows in the array rather than the effect of shadows from nearby objects, you can choose a "Self shading" option on the Shading and Snow input page instead of using the 3D shade calculator.
Otherwise, the best you can do is to divide the array into subarrays, in your case, perhaps three subarrays of 8 strings each.
