Simulation output file
- sidom
03 Jul 2012 03:40 #687
by sidom
Simulation output file was created by sidom
Is there anywhere I can find the formulas used to calculate the different parameters appeared in the output file?
I would like to know the parameters taken into account to reach the Gross Electric Output from the Total Incident thermal energy.
05 Jul 2012 15:43 #688
Replied by Paul Gilman on topic Simulation output file
For SAM's CSP models, you can see source code containing algorithms and equations for each component of the system. For a list of the source code files and instructions for finding them, please see the overview topic for the model in SAM's help system.
For example, you can find a list of the physical trough source code files in the "Trough Physical Overview" topic.
- sidom
19 Jul 2012 10:40 #689
by sidom
Replied by sidom on topic Simulation output file
I can find where this information is. Could you please accurate more where I can find it?
Thank you
Thank you
19 Jul 2012 13:51 #690
For example, for the physical parabolic trough model, the list of source code files is in the Help topic "Trough Physical Overview," under Concentrating Solar Power, Parabolic Trough Physical."
- oukili.mohamed
20 Jul 2012 14:39 #691
by oukili.mohamed
Replied by oukili.mohamed on topic Simulation output file
I noticed after the simulation, negative values ??of hourly electric energy in CSP, what's the problem?
