Field HTF energy inertial
  • loubna123
03 Jan 2019 08:25 #6579 by loubna123
Field HTF energy inertial was created by loubna123
Hello
I calculated the solar fiel warmup energy using the method descried in (sam_trough_model_type805.cpp) for empirical model but when i compare it with the calcul of Field HTF energy inertial (consumed), i don't have the same result.
how can i calculate the Field HTF energy inertial (consumed)?
I don't have the same calcul of everage temperature and Field HTF energy inertial (consumed).
the calcul warmup energy is the same of Field HTF energy inertial (consumed)???????
Yours sincerely
04 Jan 2019 11:01 #6580 by Paul Gilman
Replied by Paul Gilman on topic Field HTF energy inertial
I need more information to help answer your question:
1. Either a copy of the lines of code or line numbers from the .cpp file.
2. The name of the output variable in SAM you are comparing.
3. A copy of the .sam file you are using.
4. The equation and values you used for your calculation.
