options for batt_meter_position
- hendrj202
17 Oct 2018 13:52 #6476
by hendrj202
options for batt_meter_position was created by hendrj202
Using the SDK I find a variable batt_meter_position, but I haven't been able to find a description in any of the documentation. The options appear to be 0/1. Changing only batt_meter_position does change the outputs of the script.
Thank you.
Thank you.
17 Oct 2018 16:23 #6477
Replied by Paul Gilman on topic options for batt_meter_position
That variable determines whether the battery is connected behind the electricity meter, or in front of it.
batt_meter_position = 0 is for a behind-the-meter connection.
batt_meter_position = 1 is for a front-of-meter connection.
- ndiorio
17 Oct 2018 17:06 #6478
by ndiorio
Replied by ndiorio on topic options for batt_meter_position
That's correct, sorry for the confusion. For some of these options, we should go through and ensure the appropriate options are more clearly labeled.
- ndiorio
17 Oct 2018 17:07 #6479
by ndiorio
That's correct, sorry for the confusion, we should go through and ensure the labels are clearly defined.
23 Oct 2018 09:02 #6480
In the SAM user interface, you can see that the location of the meter, in front of, or behind the meter affects the options available for the storage dispatch controller. For example, the two peak shaving options are available for behind-the-meter applications, but not front-of-meter applications.
SAM determines whether the battery is in front of or behind the meter based on the financial model: For Residential, Commercial, and Third Party Ownership (any model with a building load), the behind-the-meter options are available. For the PPA models (Single Owner, Partnership Flip, etc.), the front-of-meter options are available.
If you are interacting with the SSC API directly, the options are not limited, so you have to be careful to enable options that make sense for the scenario you are modeling. I would recommend using the SAM user interface as a guide for setting values of SSC inputs.
