Turbine tower cost estimation
  • seyong.kim
02 Oct 2018 07:28 #6461 by seyong.kim
Turbine tower cost estimation was created by seyong.kim
Hi, I have some questions regarding turbine tower cost determined by SAM cost database.
Based on the SAM documentation review, it looks like that tower cost is included in turbine cost.
If it is, as SAM use a fixed cost per turbine rating based on 2015 installed cost for offshore turbine, change in tower cost for different hub height will not be captured.
It is also found that change in hub height does not affect substructure and foundation cost when the jacket type substructure is selected.
My conclusion is that tower cost varies with different hub height is not incorporated into system cost, except for its installation cost. Is my understanding correct?
  • Janine Keith
03 Oct 2018 11:36 #6462 by Janine Keith
Replied by Janine Keith on topic Turbine tower cost estimation
SAM does not have an explicit model for turbine cost for offshore turbines, so yes, the same cost is applied regardless of technology specifications like hub height. The cost that is applied is simply the average cost of an offshore wind turbine based on a 2015 report.
For the offshore balance of system costs, you are correct that hub height does not appear to affect the estimated balance of system costs when the jacket substructure is selected. If you are interested how that model is formulated in more detail, you can explore all of the code for the model in our open source repository. The specific file containing the offshore BOS model is: github.com/NREL/ssc/blob/develop/shared/lib_wind_obos.cpp .
Hope that helps!
Janine
