W/o solar power output difference
- FrankNam
20 Sep 2018 01:33 #6446
by FrankNam
W/o solar power output difference was created by FrankNam
HI all
I am having trouble with results from the same model but two different input weather files. The one I run with meteonorm data for a location, the other I run with ground measured data entered into an existing SAM resource library file. (any advice on doing this the "right way" would be appreciated).
Please see the graphs attached. Can anybody explain why the meteonorm profile is higher during night-time operation than the ground-measured data night time operation?
Frank
Frank
21 Sep 2018 15:14 #6447
Replied by Paul Gilman on topic W/o solar power output difference
Hi Frank,
It's hard to say what is causing the difference without seeing the SAM file and actual data. However, it appears that maybe the DNI in the meteonorm data is higher, so more energy goes into storage during the day and is available from storage at night.
