Battery Storage Discharge Issue
  • johnkern17
15 Aug 2018 06:54 #6398 by johnkern17
Battery Storage Discharge Issue was created by johnkern17
Hi:
I am modeling Solar PV with Battery Storage using a manual dispatch for the Battery Storage. I've set the manual dispatch to discharge the battery during defined time periods during Weekdays. On weekends the battery does not discharge.
I've noticed there are several weekdays where the battery does not discharge during the defined time periods. I check the battery state of charge during these occurrences to find that the battery is fully charged yet for some reason is not discharging. This happens throughout the 8760. Some dates, for example, are January 5th and February 13th-15th.
I attached the SAM File and a screenshot of the Jan 5th example.
I am struggling to find a solution to fix the issue. Any help would be very much appreciated.
Thanks in advance.
John Kern
20 Aug 2018 14:43 #6399 by Paul Gilman
Replied by Paul Gilman on topic Battery Storage Discharge Issue
Dear John,
From my initial investigation, it looks like the load goes to almost zero Jan 4-6, and then again on March 3 and March 13-17. Do those periods coincide with the periods when the battery is not discharging?
