Cell Type enum ordering mismatch
- heychrisaikens
06 Aug 2018 12:02 #6385
by heychrisaikens
Cell Type enum ordering mismatch was created by heychrisaikens
We are writing some custom wrappers around both the pvsamv1 and iec61853par modules, but are seeing a mismatch in the ordering of enum options between the two when using the SAM UI and the SSC SDKTool.
The enum for iec61853par has CdTe as the fifth option, but the SAM UI for the IEC61853 Single Diode Model option has CdTe listed third.
In addition, the only field in the SDK Tool that calls out the enum also has a different order (see below).
iec61853par - type: monoSi,multiSi/polySi,cis,cigs,cdte,amorphous
pvsamv1 - 6par_celltech monoSi=0,multiSi=1,CdTe=2,CIS=3,CIGS=4,Amorphous=5
Can anyone advise on if the orders are actually different for cell type between pvsamv1 and iec61853par, or if the SDKTool just has the order listed wrong? Thank you very much for the assistance!
07 Aug 2018 16:02 #6386
Replied by Paul Gilman on topic Cell Type enum ordering mismatch
That enumeration is defined here as
github.com/NREL/ssc/blob/develop/shared/lib_iec61853.h
So the order in the SAM user interface is correct.
The model uses the
input to choose an initial guess value for the numerical solver algorithm to help it find a solution. It is not a physical parameter of the model.
We are working on some improvements to the solver for the next version of SAM.
enum { monoSi, multiSi, CdTe, CIS, CIGS, Amorphous, _maxTypeNames };
The model uses the
type
