Optimization of field layout parameters
  • Zouhir1995
18 Jun 2018 09:27 #6292 by Zouhir1995
Optimization of field layout parameters was created by Zouhir1995
I am dealing a sensitivity analysis of the energy yield of an existing tower plant to the layout method by means of SolarPilot, so i want to investigate the effect of different radial spacing methods and to compare them, but to avoid meaningless comparison i should optimize each one of this method. my question is if the tower height and receiver dimensions are already defined and knowns, is it correct to optimize only the parameters related to field configuartion, those highlighed in the figure attached
i need help with that thanks
