Parabolic Trough Tilt
  • Allan54
18 Apr 2018 21:32 #6191 by Allan54
Parabolic Trough Tilt was created by Allan54
Hi there, I live in a northern latitude in Canada. When I run the Parabolic Trough model and include some tilt I see less heat output from the field, providing I enter positive values - ie closer to vertical. But when I tilt the trough downward with negative values, like -10 deg the trough output goes up quite a bit. Am I getting valid results? Thanks Allan
19 Apr 2018 09:06 #6192 by Paul Gilman
Replied by Paul Gilman on topic Parabolic Trough Tilt
Dear Allan,
The collector tilt angle for the parabolic trough model is defined as follows (from SAM's Help system):
The angle of all collectors in the field in degrees from horizontal, where zero degrees is horizontal. A positive value tilts up the end of the array closest to the equator (the array's south end in the northern hemisphere), a negative value tilts down the southern end. SAM assumes that the collectors are fixed at the tilt angle.
Note that this definition is different from the tilt angle input for the photovoltaic models.
  • Allan54
22 Apr 2018 11:42 #6193 by Allan54
Replied by Allan54 on topic Parabolic Trough Tilt
Boy do I ever appreciate the help you provide. Thanks to all of you. Allan
