the question of flow velocity in she solar field
- lixiaofei
12 Jun 2012 02:25 #612
by lixiaofei
the question of flow velocity in she solar field was created by lixiaofei
I want ask one question: which are the detailed restrictions of field flow velocity? what is the number of the min field flow velocity or max? Thanks .
12 Jun 2012 16:06 #613
Replied by Paul Gilman on topic the question of flow velocity in she solar field
For the physical trough model, SAM calculates the minimum and maximum field flow velocities using the following equations:
Min Field Flow Velocity = ( Min Single Loop Flow Rate x 4 ) /
( HTF Density at Field Output * pi
* (Absorber Tube Inner Diameter)^2 )
Max Field Flow Velocity = ( Max Single Loop Flow Rate x 4 ) /
I have added these and other equations to the physical trough model Help topics that will be included in the next update to SAM 2012.5.11.
