Using SAM to get the blended $/kWh from interval data
- cgirongu
15 Jan 2018 10:02 #6022
by cgirongu
Using SAM to get the blended $/kWh from interval data was created by cgirongu
Hello all,
I'm working with a couple of companies that do not like sharing their electric bills when they put out a request for proposals (RFP), as many times they get special rates after negotiating with the utilities. This represents an issue when they try to get accurate quotes for on site renewable energy.
I was wondering if there is a way to use SAM with interval data and rate as inputs, and obtain blended rate per kWh - $/kWh year or monthly average. This would allow the companies I'm working with to evaluate renewable energy internally to pick the ideal locations, and when they are ready, reach out with RFP's sharing only the blended rate; which would go a lot smoother.
15 Jan 2018 15:34 #6023
Replied by Paul Gilman on topic Using SAM to get the blended $/kWh from interval data
I think you should be able to calculate a "blended" rate from SAM's results. Can you tell me exactly what it is? For example, is it the total monthly or annual bill in $ divided by the total power delivered by the grid in kWh?
