Freeze Protection
  • Mahdi AlSarraf
14 Dec 2017 05:04 #5970 by Mahdi AlSarraf
Freeze Protection was created by Mahdi AlSarraf
Hi I modeling a process heat parabolic trough and a chose Therminol VP-1 as a HTF, I chose a 40 C for freeze protection temp, 90 and 350 as a loop inlet and outlet HTF tem. In the summary I get the annual thermal freeze protection equal zero. Is that possible?
Thank you.
15 Dec 2017 09:00 #5971 by Paul Gilman
Replied by Paul Gilman on topic Freeze Protection
Dear Mahdi,
You can look at the field temperature data in the results to see whether the temperatures fall below the freeze protection temperature to confirm those results.
