How to POA irradiance for tilted surface
  • vshyam1992
01 Nov 2017 08:29 #5819 by vshyam1992
Hi
I am working on a masters thesis, In here I used TMY2 and TMY3 format to get the hourly GHI irradiance(W/m2).I am trying to find the hourly POA irradiance(W/m2) from whether a file, its showing "NAh". Can you please help what am I doing wrong in here. Is there any way to find the hourly POA irradiance?
Please suggest me
01 Nov 2017 10:07 #5820 by Paul Gilman
Replied by Paul Gilman on topic How to POA irradiance for tilted surface
SAM's photovoltaic models report the POA irradiance for each subarray. For a system with one subarray, the variable for the solar irradiance incident on the top of the module surface is "Subarray 1 POA total irradiance nominal."
The "Irradiance POA from weather file" variable is for a weather file that includes POA data. SAM can run simulations using POA data measured in the field at the array. If your weather file does not contain POA data, SAM displays "NaN" for "not a number" for that variable's value.
  • vshyam1992
01 Nov 2017 16:33 #5821 by vshyam1992
Replied by vshyam1992 on topic How to POA irradiance for tilted surface
Hello Paul,
Do you have any tutorial how to get the POA whether data (W/m2)? I want the hourly data of solar irradiation for the tilted surface in W/m2. Is it "subarray 1 POA total irradiance nominal data "
Thank you in advance,
Shyam Busineni
02 Nov 2017 11:22 #5822 by Paul Gilman
Dear Shyam,
Yes, that is correct. You can export that data from the Data Tables tab on the Results page.
  • vshyam1992
05 Nov 2017 17:23 #5823 by vshyam1992
Hello Paul,
I am working on the comparison between SAM and RETScreen software. In this, I am trying to find Solar irradiance for the tilted surface on PV module for both software. In RETScreen, I have monthly solar irradiance for the tilted surface in KW/m2/d (very straightforward results). In SAM, I used hourly "subarray 1 POA total irradiance nominal" and then converted to monthly (Kw/m2/d). In this analysis, there is a huge variation in the results. IN SAM, it is showing total annual irradiance as 4.0kw/m2/d and in RETScreen, its showing annual irradiance as 2.84KW/m2/d.
I am not sure where I am making mistake, am I making mistake in inputting data in SAM. But, I watched webinars for inputting data. Is there any problem with TMY3 weather file? or Do I have to use any DHI, DNI data to convert in POA irradiance?
Can you please help this analysis, I can attach the attachment if it is needed
Thanks in advance
Shyam
07 Nov 2017 09:33 #5824 by Paul Gilman
Dear Shyam,
SAM can read weather files in the TMY3 format. Are you using the same weather file for both models? Also, please check that the tracking, tilt, and azimuth inputs are the same in both models.
SAM reports the monthly "POA irradiance total nominal (kWh/mo)" that may help you confirm that your calculation is correct. You can find that on the Data Tables tab on the Results page.
By default, SAM uses the DNI and GHI data from the weather file to calculate the POA irradiance.
