Scripting to Input Hourly Electric Load Data
  • pspitsen
22 Sep 2017 10:31 #5742 by pspitsen
I am writing a script to input different hourly load profiles, but am having trouble getting SAM to recognize the input data. I have tried csv files with either 8760 rows or 8761 rows (where the first row is a place holder) of data organized in a single column, however neither work.
The code I have been trying is:
active_case('untitled');
set('load_model', 1);
set('normalize_to_utility_bill', 0);
set('load', real_array(read_text_file('C:/Users/pspitsen/Desktop/load.csv')));
simulate();
I attached my LK script and my load csv for reference.
Any help would be greatly appreciated. Thanks!
25 Sep 2017 17:10 #5743 by Paul Gilman
Replied by Paul Gilman on topic Scripting to Input Hourly Electric Load Data
I assume that you are writing an LK script in the SAM user interface, not in SDKtool.
Try this instead:
fname = 'C:/Users/pspitsen/Desktop/load.csv'; arr = csvread( fname, {'skip'=1,'numeric'=true,'table'=false} ); for (i=0;i<#arr;i++) //convert 2D array to 1D arr[i]=arr[i][0]; set('load_user_data',arr);
Also, if you want the results in SAM to change when you use the
simulate()<code> function, you can use its parameters like this: <code> msg = ''; // string to store simulation messages simulate( msg, true ); // set second parameter to true to update SAM's results page outln( msg );
  • alexaura
17 Oct 2017 07:17 #5744 by alexaura
Replied by alexaura on topic Scripting to Input Hourly Electric Load Data
Thanks for the sample code, it really helped in the work!
