Multi Inverter Single system design
- Ashokprasadaryal
17 Sep 2017 11:45 #5719
by Ashokprasadaryal
Multi Inverter Single system design was created by Ashokprasadaryal
I wanted to design a 115kWp project with 4 inverters 25kW and fifth inverter 15kWp. How is it possible? How can i use different and more than 1 inverter in a single system? Thank You.
Also, how can i import new inverter data during design which is not originally available?
18 Sep 2017 16:19 - 18 May 2023 09:40 #5720
Replied by Paul Gilman on topic Multi Inverter Single system design
For now, SAM can only model a system with a single type of inverter, and only inverters with a single MPPT input. You could use the Combine Systems to combine results from two different cases in your SAM file: One case would be for the portion of the array connected to the 4 25kW inverters, and the other case would be for the portion of the array connected to the 15kW inverter. Click the Macros button (it's under Simulate) to find the macro, and read the instructions to see how to set it up.
UPDATE: As of SAM 2021.12.02, the Combine Cases macro is replaced by the Calculate generation profiles and nameplate capacity from open cases option on the Power Plant page for the Generic System model and Generic Battery model. See the SAM YouTube channel for a short tutorial .
For an explanation of how to model an inverter that is not in the CEC inverter library, see:
sam.nrel.gov/node/69678
Last edit: 18 May 2023 09:40 by Paul Gilman.
04 Feb 2019 09:22 #5721
As of Version 2018.11.11, SAM can model inverters with up to four MPPT inputs, and each subarray has its own "modules per string" input so the array can have up to four different string lengths.
See the release notes for a full list of new features.
