Cannot retrieve utility rate data from OpenEI.org
  • takaih
20 May 2012 18:40 #574 by takaih
When trying to get utility data with "OpenEI Utility Rate Database", SAM responds with "Error: Could not retrieve JSON data for utility companies" and has trouble loading utility companies data. (Also "JSON.." hyperlink in that window is not linked to a meaningful site.)
Is this caused by a bug or some setting is required?
21 May 2012 09:47 #575 by Paul Gilman
Replied by Paul Gilman on topic Cannot retrieve utility rate data from OpenEI.org
We've run a couple of tests that suggest that the connection between SAM and the utility rate database is working.
Can you open the following website in your web browser?
en.openei.org/wiki/Gateway:Utilities
  • tgwinn
12 Jul 2012 02:00 #576 by tgwinn
I'm having the same issue, but I am able to open the site you listed. Maybe it's a firewall issue?
  • WGS
22 Mar 2014 13:02 #577 by WGS
I'm getting this same error, but I can open the link. Has there been any resolution to this issue?
Will
24 Mar 2014 15:54 #578 by Paul Gilman
Hi Will,
There was a new problem with the utility rate database connection in the last few days (as of March 24, 2014) that we resolved today. The connection should be working properly now.
