Use LK to import user defined TOD array
- Harry Han
06 Aug 2017 21:34 #5615
by Harry Han
Use LK to import user defined TOD array was created by Harry Han
Dear Paul
Is it possible that I can import user defined TOD array into power tower model with LK? The user defined TOD array is consisted of 8760 numbers.
Thank you!
Han
Thank you!
Han
08 Aug 2017 15:36 #5616
Replied by Paul Gilman on topic Use LK to import user defined TOD array
Dear Han,
Yes, the variable for the time series TOD multipliers array is
Be sure to enable that option on the Time of Delivery Factors page, by choosing Time of Delivery Factors Timestep at the top of the page. You can also do that programmatically in LK with
dispatch_factors_ts
set('ppa_multiplier_model',1)
- Harry Han
10 Aug 2017 19:12 #5617
by Harry Han
Replied by Harry Han on topic Use LK to import user defined TOD array
Hi Paul
Thank you Paul. Is it possile that I can also use time series system control dispatch schedule?
I have checked the single owner module, the related parameters are dispatch _sche_weekly and dispatch_sched_weekend. There is also a variable named is_dispatch_series and dispatch_series. Can I set is_dispatch_series to be 1 and then import dispatch_series?
Best reagards!
Han
Best reagards!
Han
- Harry Han
10 Aug 2017 21:48 #5618
by Harry Han
Dear Paul
Where can I find the detailed description of the module tcsgeneric_solar and tcsmolten_salt? And also some of output parameters can not be found in the module browser for singleowner module. How can I get this informations?
Thank you very much!
Han
Han
11 Aug 2017 15:39 #5619
Dear Han,
We do not have detailed documentation for those compute modules. SAM will soon be an open-source project on GitHub.com, so you could research the source code itself to learn more about how the models work.
Which singleowner outputs are you having trouble finding in SDKtool?
