Questions in inverter module database and output ac power of a solar inverter.
- Nisarg
12 Jun 2017 06:35 #5512
by Nisarg
Questions in inverter module database and output ac power of a solar inverter. was created by Nisarg
Hi there,
I am doing a research project on Solar PV plant modelling. I got the excel file of inverter parameters at sam.nrel.gov/sites/default/files/sam-library-cec-inverters-2015-6-30.csv
Certain queries I have, please answer if possible.
1. Where can I get AC Output power (Pac) generated by the inverters?
2. What is PDc0?
3. Is Vdcmax given in excel file the same as
VDC described in SANDIA Inverter model?
Thank you in advance.
Sincerly,
Nisarg.
2. What is PDc0?
Sincerly,
Nisarg.
12 Jun 2017 11:54 #5513
Replied by Paul Gilman on topic Questions in inverter module database and output ac power of a solar inverter.
Dear Nisarg,
The parameters in the CEC inverter library are for the Sandia inverter model, and you can find descriptions of the model parameters in the model's documentation, which is listed on the Performance Model documentation page:
sam.nrel.gov/performance
The library lists the rated AC power output of the inverters. You can run SAM to calculate the inverter AC power output for the inverter installed as part of a photovoltaic system.
