Linear Fresnel outlet steam conditions
  • samj
09 May 2012 12:52 #552 by samj
I’ve 2 questions in relation to modeling a Fresnel system with SAM:
a) Is there a way to specify a constant steam temperature at the field outlet or turbine inlet (i.e. steam is only delivered to power block when specified temperature can be obtained)? I can only see how to input steam conditions at Design Point.
b) How do I set a maximum steam flow rate (at turbine inlet, or in single collector loops)?
Thanks in advance.
