Runtime error using macro for Electric Load
- swierson6808
06 Jun 2017 10:03 #5500
by swierson6808
Runtime error using macro for Electric Load was created by swierson6808
When I try to run macro for Electric Load after choosing LargeOffice I get the following error script:
TMY3 ID: on":"1
Macro did not finish.
[97] runtime exception at line 97: array index out of bounds at 1010 (length: 1010)
Please help
TMY3 ID: on":"1
Please help
06 Jun 2017 16:51 #5501
Replied by Paul Gilman on topic Runtime error using macro for Electric Load
That error might be caused by the location of your weather file being too far from one of the TMY3 sites. Would you mind telling me the latitude and longitude of the location you are trying to model?
- swierson6808
07 Jun 2017 13:25 #5502
by swierson6808
Replied by swierson6808 on topic Runtime error using macro for Electric Load
Hi, Yes. It is in Nicaragua. The lat is 12.63 N and long is -87.13 E
Best Regards,
Scott
Best Regards,
Scott
12 Jun 2017 11:22 #5503
Dear Scott,
The building load database only has data for the 1,454 stations used to generate data for the old NSRDB TMY3 data set. Those stations are all in the United States, and are listed on the TMY3 website:
NSRDB 1991-2005 Update
That means that it is not possible to use SAM's Download Electric Load macro to download load data for locations outside of the U.S.
Note that the most up-to-date weather data from the NSRDB is available via the NSRDB website:
nsrdb.nrel.gov/
nsrdb.nrel.gov/
