Commercial
- saman1368
28 Apr 2017 12:11 #5392
by saman1368
Replied by saman1368 on topic Commercial
I've added a model, I am open to change the module and inverter or any other configuration. Being honest I'm so new to SAM and trying to just forecast a solar load shape for industrial, commercial and residential sectors. Then later I will run regression and model it in R or excel.
for commercial and residential I modeled two model one rooftop on the roof with pitch and 2KW and for the commercial 30KW system both ground mounted and rooftop mounted but for industrial such, as solar farms, I have absolutely no idea.
- saman1368
03 May 2017 08:57 #5393
by saman1368
Dear Paul
Did you get my model , it's attached to original post
03 May 2017 16:02 #5394
Replied by Paul Gilman on topic Commercial
In the file you attached to your original post, you used the PPA Single Owner financial model, which does not require an electric load. It is also for a 20 MW system. Your assumptions and the results look reasonable.
